Hi there,
I've newly set up an MX64 "security appliance" (router, VPN) and the wireless AP model MR33. In the MR33 I did set the SSID "Addressing and traffic" to "Bridge mode: Make clients part of the LAN — Meraki devices operate transparently (no NAT or DHCP). Wireless clients will receive DHCP leases from a server on the LAN or use static IPs. Use this for wireless clients requiring seamless roaming, shared printers, file sharing, and wireless cameras." which allows all devices to be on the same set of IP addresses (10.0.1.x). It is also set to dual band operation.
When I first configured the AP, my already-configured Google Nest Hub reconnected to the new network as I'd set up the new network with the same name/password as the old wireless one. However the Google Home app would not see the Nest Hub, so I decided to reset the Hub.
With the Nest Hub reset, the Google Home app sees the Nest Hub as a new device and starts setting it up, but once it gets to the stage of connecting it to my wifi network, it gets stuck. I see an error in the Google Home app that says:
"Something went wrong: (Nest Hub) may be set up, but would could not communicate with it from your iPhone. It's possible that your Nest Hub and iPhone are connected to networks that are unable to talk to one another. This may require a small change to your Wi-Fi settings"
I've reset multiple times to try again, with the same result. I know some IoT devices don't do 5 Ghz, but the Nest Hub apparently does, and the network is set to dual band as noted above.
I'm at a bit of a loss… is there a change to my SSID settings that I should make to get this to connect?
-Joseph
