Global client bandwidth shaper on the Meraki
RahulPrasadh
How to configure a global client bandwidth shaper on the Meraki of 100MBPS/per client. With the exception of IPs in the range and ignoring the shaper and having unlimited bandwidth. Please share If there's any documentation that could support configuration.
RaphaelL
Hi ,
I assume you are using a Meraki MX. If so you can configure a global shaping of 100Mbps in the page : SD-WAN & traffic shaping
To have some clients ignore the shapping you can create a Group Policy and do the same thing but configure : Ignore bandwidth
You can then apply that Group Policy to a VLAN or directly to clients.
RaphaelL
Hi ,
RahulPrasadh
Creating a QoS rule with those subnets won't work? with unlimited bandwidth and high priority.
RaphaelL
Yes , that should also work. There are more than 1 way to achieve your goal
