I'm trying to generate an CSV of MX devices with NAT Type 'Unfriendly' using the API. When looking at the documentation there's nothing i can find that would supply me with this information.
Another way for us to determine there's NAT problems is by looking at the Uplink decision.
Has anyone been able to get this info, perhaps by using a workaround, using the API?
Solved! Go to Solution.
I am afraid this is not possible at the moment (had a quick look in the APIs, but couln´t find something related to it). Maybe an upcoming API call
Also I don´t know an workaround, but not the most familiar API user 😄
If you know which WAN you want active, you can use "Return the uplink information for a device." to pull the... current WAN in use. 🙂 As a proxy.
Not sure of this but maybe NAT:Unfriendly is noted in the event log. If so you should be able to identify the MXs from there.
