Geo location base rule
Vishal07
Hi All,
Can we configure geo location base rule/access rights for client vpn and port forwarding rules ?
rhbirkelund
Unfortunately no, it is not possible to apply rules and portforwardings based on GeoIp.
For client VPN, if you use Cisco Secure Connect and a SAML provider that can enforce Geo restrictions, yes.
https://duo.com/blog/easily-enable-conditional-access-by-country-with-duo
Vishal07
Hi Philip,
We dont have duo.
You don't have to have Duo.  You can use any Idp that supports geographic restrictions.  Another example is AzureAD/EntraID with an appropriate licence for conditional access.
I'm just giving you what is required to do what you have asked.  You need to buy all the appropriate bits of the solution for it to work.  Buying only some of the bits ... well that just wont work.
