GEO-FENCE
JED2021
GEO-FENCE
Is it possible to Geo-Fence on an MX-250?
2 REPLIES 2
Brash
You can perform geoblocking using L7 firewall rules. It requires a minimum of advanced security licensing.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Firewall_Settings#Geo-IP_Based_F...
BlakeRichardson
Yes it is possible as Brash mentioned already, I do this for one gateway on a public facing system that only requires access from a specific country. However if possible I would use this along side a rule allowing ONLY specific IP traffic.
That way you have a multi sided approach that should hopefully keep things secure as hackers will use bots located all over the world to do their dirty work so geo blocking on its own isn't secure.
