Firmware Changelog? And dates of release?
PeterJames
Hi All,
Does anyone have a full list of the latest firmware over the last year and the dates they were released? My Google search skillz have failed me.
Thank you,
Peter James
If you're too lazy to click through all those versions... That page loads the whole version history at once. Look for the variable "versions" in the source code, with the releasedAt and createdAt timestamps.
E.g.
Spoiler
{"id":"1825","name":"MS 10.45","major":10,"minor":45,"changelog":"[Alerts] This version addresses an issue where MS22/42/220/320 series switches may hang during upgrades. Upgrades TO this release will reboot affected switches immediately prior to executing the upgrade.\r\n[Alerts] 10.45 addresses a firmware update issue for MS355 series switches. For all other models, this version is equivalent to 10.44.\r\n[Additions] Support for MS355/MS450 Series switches\r\n[Additions] Enhanced Storm Control (not available on MS22/42/120/220/320)\r\n[Additions] Dynamic ARP Inspection (not available on MS22/42/120/220/320)\r\n[Additions] SM Sentry Wired Security Integration on MS\r\n[Additions] IPv6 ACLs (not available on MS22/42/220/320)\r\n[Additions] STP Anomaly detection\r\n[Additions] STP Loop Guard\r\n[Additions] Equal Cost MultiPath (ECMP) routing (not available on MS42/320/210/225)\r\n[Additions] Increase minimum fan speed on MS225-48LP/FP series switches to address a condition that can result in fan failure\r\n[Additions] Reduced bootup times for MS120 series switches\r\n[Additions] Unidirectional Link Detection (UDLD)\r\n[Additions] Support for Multi-Host and Multi-Auth access policy modes\r\n[Additions] Ability to download diagnostic data about the device from the local status page\r\n[Bug Fixes] Switch can crash and reboot while snooping high volume DHCP transactions over long periods of time\r\n[Bug Fixes] MS355 series switches may not auto-negotiate mGig speeds correctly\r\n[Bug Fixes] Ports on MS355 series switches may remain down after cable testing\r\n[Bug Fixes] Multicast routing on MS355 series switches does not function correctly\r\n[Bug Fixes] Address an issue where MS355 switches do not initiate firmware updates\r\n[Known Issues] SM Sentry does not support Windows based clients\r\n[Known Issues] MS425 series switches do not forward frames larger than 9416 bytes (present since 9.0)\r\n[Known Issues] Drop unknown multicast drops all IPv6 multicast on MS210/225/250/350/410/420/425 series switches and can cause switches to become unreachable\r\n[Known Issues] The RADIUS test widget in Dashboard does not function correctly on MS22/42/220/320 series switches (Present since version 10.0)\r\n[Known Issues] MS350-24X and MS355 series switches do not negotiate UPoE over LLDP correctly (Present since version 7.x)\r\n[Known Issues] Slower than expected port authentication speed on MS355 series switches \r\nVarious performance and stability improvements","networkType":"switch","isBeta":false,"isLatestStable":true,"isReleaseCandidate":false,"isLatestBeta":false,"isAvailableUpgradeVersion":true,"createdAt":1549395409,"updatedAt":1549398558},{"id":"1708","name":"M 0.1","major":0,"minor":1,"changelog":"","networkType":"sensor","isBeta":true,"isLatestStable":true,"isReleaseCandidate":false,"isLatestBeta":false,"isAvailableUpgradeVersion":true,"createdAt":1520565620,"updatedAt":1544580112}
5 REPLIES 5
PeterJames
I have found an unofficial source:
https://updateyourwifi.com/wifi5/cisco/meraki_changelog.html
But cannot see dates of release.
Thank you,
Peter James
at Organization > firmware-upgrades you can find the  Release notes/changelog of current and previous versions.
Also the release dates of the latest stable firmware, but  no dates of the previous versions.
NolanHerring
I don't know of any 'full list' compiled. You would have to go to Org>Firmware Upgrades and then click on the release notes yourself, and from there you can go forward or back to previous or new versions. Not sure you can get old date info.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
E.g.
Spoiler
Haha nice find!
Thank you,
Peter jJame
