Fiber Connections
DGrom
Fiber Connections
I am relatively new to this, but i have some questions.
I have a ATT Fiber Connection  that is SPF+ and LC.  Would this type of connector work?  It is 10G but i am a bit confused on the duplexing on it.   The connector in question:
https://meraki.cisco.com/product/switches/switches-accessories/switches-accessories-sfp-plus/ma-sfp-...
I just want to make sure before i tell my company what to buy. Also does anyone here have any suggestions on good reading for Fiber cables?
Thanks,
Dan
I think you mean SFP/SFP+ - yes, you need to buy those as well.  They need to match the same type as what AT&T are using, for example single mode, multi-mode, SR/LR/LRM.
11 Replies 11
What Meraki device and model do you have?
DGrom
Mx-95.  I got this off the product documentation.
Check it out.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
https://meraki.cisco.com/product/security-sd-wan/appliances-accessories/ma-sfp-10gb-sr/
rhbirkelund
The MX95 has 2x dedicated 10Gb SFP+ ports for WAN, as well as 2x 10Gb SFP+ ports for LAN.
So yes, if ATT provides the same connectors it should definitely work.
To ensure compatibility with Meraki, you should probably stick to Meraki optics aswell, as @alemabrahao also references to.
DGrom
I am sticking with Meraki as it just seems like a better idea for support.  The meraki still needs cards as they do not come with them correct?
rhbirkelund
What cards?
What do you mean by cards?
I think @DGrom means transceivers, the SFP+ to LC converter.
DGrom
I do, Sorry.  I am just learning this. I mean transceivers.
