The MX95 has 2x dedicated 10Gb SFP+ ports for WAN, as well as 2x 10Gb SFP+ ports for LAN.
So yes, if ATT provides the same connectors it should definitely work.
To ensure compatibility with Meraki, you should probably stick to Meraki optics aswell, as @alemabrahao also references to.
	LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
