Facebook login mx68w
Acme
Hi All
I have a MX68W and I have set it up for Facebook Wifi but it will not work?
I have a separate network that has a MR33 and thru the wireless tab I can set it up and it works properly.
What am I doing wrong????
Thank you for the help
AjitKumar
I understand authentication in MXes works in a different way as they are Gateway devices.
You may apply this on VLANs not on SSIDs.
Screenshot attached for reference.
Note : I have never tried configuring Facebook Login with MXes.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
The WiFi integrated into MX's does not support splash page authentication - and consequently does not support Facebook authentication.
I just spent 2 hours on the phone with tech support.
Why do they not know that??
