FW Supported features
route_map
just checking to see if Meraki MX's support the following features
Support traffice filtering by IP host add/range and deep packet inspection at wire speed?
Manageable via SNMPv3, supports snmp trap messages
Support 802.1q
The firewall shall support syslog protocol for reporting events?
Continue to log events while under attack (DOS, DDOS, etc)
THe FW should support DNS functionality for local host that resolves uo to a public DNS
CptnCrnch
Regarding your questions:
DPI is not possible at Wire Speed. But that's the case for every other firewall out there. Please find throughput figures here: https://meraki.cisco.com/products/appliances/#models
Management is done completely cloud-based (via Dashboard), you could also leverage the API for that. SNMPv3 could be used for monitoring puposes though: https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/SNMP_Overview_and_...
> Support 802.1q
Yes, but you'll have to activate VLANs first: https://documentation.meraki.com/MX/Networks_and_Routing/Configuring_VLANs_on_the_MX_Security_Applia...
Yes, not only Syslog:
https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/Meraki_Device_Repo...
https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/Syslog_Server_Over...
As long as the box is up and running it will produce logs. Perhaps Meraki could elaborate further on that.
What exactly do you mean? MX itself won't be able to do that but could leverage Cisco Umbrella to add DNS layer enforcement.
1 Reply 1
CptnCrnch
> Support 802.1q
