FTP active outbound connection from MX64 LAN clients
davymartu
Hi guys,
I've Meraki MX64 FW version 16.16 and we have a problem connecting to an external public FTP server through ftp command of windows.
Outbound connection from LAN of Meraki on port 21 of external FTP server connects successfully but data connection doesn't work (if I type DIR the connection hangs).
I know that FTP passive mode isn't supported by ftp.exe windows client and also that passive mode can be activated on external FTP server, but I don't have control on external FTP server.
I read that outbound connection of this type requires a particular NAT traversal implementation (in ex. ALG ).
Does MX NAT supports correctly fix up NAT for active mode connections to allow the return traffic?
Thanks in advance
Davide
KarstenI
There is no "NAT Fixup" on the MX. You need to change to either passive mode or a different protocol. Using plain FTP is a little bit like the 80th. Yes, the music was better, but not the typically used protocols.
6 Replies 6
KarstenI
davymartu
Hi @KarstenI , thanks for your nice response 🤣
I thought that MX has a particular feature like this but I agree with you that plain FTP is an "old" protocol but a lot of systems still using it.
I tried with firewall of other vendors and the majority of these give you a choiche for using this "old" protocol.
I think that give to the users a choice is better than judge what is "new" "old" "worst" or "better".
KarstenI
I assume it was a pure business decision not to implement fixups like how they are available for example on the ASA. And yes, I also have customers still using FTP. But many of them moved to other protocols when migrating the firewalls to Meraki MX. Most of them now use file shares based on HTTPS (like https://www.directorylister.com), some moved to Cerberus (https://www.cerberusftp.com). But these were always servers hosted by the customers. When being a client, they just used client apps that supported passive mode.
FileZilla is free, has a command line, and supports passive FTP ...
BlakeRichardson
Just because systems still have it doesn't mean you should use it, Windows still supports SMB v1 which is incredibly insecure but I wouldn't use it.
davymartu
Thanks to all for responses. Unfortunately this FTP Server is not ours. But I have suggested to our partner to move at another file transfer solution (like SFTP). Thanks to @KarstenI for you suggestion, DirectoryListener is a great project for this approach.
