Friends, customer requesting event logs and web content filtering reports for minimum of one year. Here's the verbiage they provide for content reports:
"For web content filtering, it must allow to display reports from the same solution (online) and generate reports in real time and historical, with a minimum period of one (1) year."
What solutions can we have offer or propose? Any caveats?
Hi @johnnyngena
What are your thoughts on "syslog" service.
Thank you. What about the web content historical reports for one year? Can that be done?
Hi Johnnyngena,
You can tell your MX appliance to export URL logging via Syslog by assigning the "URLs" role in the Dashboard Syslog configuration.
This section of the documentation details what the Syslog entry will be formatted as:
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Syslog_Server_Overv...
It will look like this in the Dashboard configuration:
Additionally, you can also set up Netflow reporting as well, per the following documentation:
https://documentation.meraki.com/MX/Monitoring_and_Reporting/NetFlow_Overview
Both Syslog URL reporting and Netflow reporting will allow logging up to a year.
-Donovan
DJDonovan, thank you, so how can one retrieve the URL logs once they are stored? Is there a software or a way we recommend?
Hey Johnnyngena!
The Meraki Dashboard reports content filtering event logs (among others) in the Network Wide -> Event Log on the dashboard. Events are stored in this log for up to 3 months. If extended historical logging is necessary, you will need to implement a Syslog server and have your Meraki hardware export to it. This will allow you to store events beyond 3 months.
Documentation on setting up reporting to a Syslog server can be found here:
https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/Syslog_Server_Over...
Let me know if you have any other questions!
-Donovan
As above, syslog is your friend here.
