Error on Cisco Meraxi in Azure
sury
I have deployed Cisco Meraxi vMX in azure but receiving error virtual machine agent status is not ready.
As it is manage instance not sure how to fix this error. Any one come cross such issue and how to fix this
4 REPLIES 4
Make sure you deployed it with a zone of "None".
Get the public IP address from the Azure console and point your web browser at it (using HTTP).  See what error the VMX is reporting.
The last one I did that had this issue was because DNS name resolution was failing.
sury
Able to access the Meraki with IP and it's healthy, do not see any error. But how can resolve that alert/issue.Meraki-error.PNGMeraxi-Health.PNG
Mloraditch
The vMX doesn't  use the Azure extension for VM management. Every single one of my vMXs has the "error". It's spurious.
sury
Thanks for update, but did you check with TAC and any confirmation that this error can be ignore.
