Early Access - NAT Exceptions with Manual Inbound Firewall
RaphaelL
Hi !
Just noticed that
is now available via the Early Access program
Org -> Early Access -> NAT Exceptions with Manual Inbound Firewall
https://documentation.meraki.com/MX/Networks_and_Routing/NAT_Exceptions-No_NAT_on_MX_Security_Applia...
This is nothing new , but you don't have to contact support to enroll which is nice !
TYehlik
WARNING: There is a known issue after enabling the No-NAT with Manual Inbound firewall Early Access Feature. The UI shows the default inbound firewall rule as Deny Any Any, but if the inbound firewall table has no other rules created this will be enforced as an Allow Any Any rule. We are actively working on correcting this behavior.  In the meantime, adding any rule to the inbound firewall will correct this behavior and the default rule will be enforced as expected.
TYehlik
The issue mentioned above has been resolved.
Mloraditch
Coincidentally I had previously enabled this somewhere to test and things were working, enabled at another client today to further check things out and I guess this issue popped up an issue as inbound client vpn (AnyConnect) was shut off.
The documentation doesn't seem clear that this will happen nor what rules are necessary to avoid it.  Might be helpful to spell out examples in the documentation of how to allow this.
TYehlik
Thank you for the recommendation. We will look into clearing up the wording in the documentation.
