Dual redundant mx devices but with separate ISP on each WAN 1 port
CarlT
Hi All
I have 2 Meraki mx devices and 2 different ISP's, but with a /30 ip from each ISP only.
My plan is to have ISP 1 into MX1 and ISP into MX2.
Although I wont be able to so any sd wan routing this way, would it be OK from a HA standpoint and work correctly ?
Cheers
Osberg
Sure that can be done, without any issue.
Frank Osberg | Domain Architect @ Solar A/S
LinkedIn - Twitter
Found this helpful? Give me some Kudos! Much Thanks
1 Reply 1
Osberg
LinkedIn - Twitter
