Dual concurrent wan uplinks on z3
PrayankC
Just browsing
Can we define flow preferences on z3 such that both the uplinks can be used at the same time based on the destination ?
1 REPLY 1
Adam
If you have redundant uplinks you'd just want to setup Load Balancing at Security Appliance>Traffic Shaping.
Flow preference are only really designed to be used if you want traffic to use one of the WAN connections over the other.  A typical example of this may be your VOIP traffic.  Maybe WAN1 is an ultrafast low latency pipe and WAN2 is a slower high latency pipe.  Load balancing internet over both of those is fine but you may want your phone traffic to prefer WAN1.  In that case you'd setup a flow preference for your VOIP traffic with destination and WAN1.
