Does Meraki MX support Source base route by subnet not a whole vlan ?
EricZ
We want to route some specific ip addresses to a destination ,but i only found meraki can do this by whole VLan ? Is there a way to realize this requirement ?
8 Replies 8
KarstenI
You can also configure it for a static route that is available on the MX. This could be a specific subnet in your environment. But be aware that this is only a source-based default route, not something like PBR on other platforms.
EricZ
But as i see ,static route can only be set up by destination ?
KarstenI
The static route will become the source subnet in the source-based routing dialog.
EricZ
But in source-based routing ,the source can only be a whole VLAN ,can input lie  172.16.226.0/26
EricZ
It's not flexiable for us realize some demands.
Brash
As said above, you're correct - you cannot source specific IP's or subnets.
It is per-VLAN
"Source-Based Default Routing is a per-VLAN default route feature."
Source Based Default Routing - Cisco Meraki Documentation
Aamir
Hi for this feature Source-Based Default Routing does it mean i have to define VLAN's on MX and MX becomes default gateway for all vlans in the network?
