Does MX device can support dual active ?
kuni
Main circuit : MPLS
Backup circuit : Internet (Site-to-Site VPN)
In this case, Does a MX can support dual active ?
I'd like to send traffic both MPLS and Internet as active-active.
Is it possible ?
KRobert
LoadBalancing.PNG@BrechtSchamp is on-point here. If you have 2 WAN up-links, then you can enabled load balancing and traffic shaping will steer to whatever WAN you decide via Flow Preferences.
BrechtSchamp
kuni
Thank you for your answer.
You mean that to use dual active, It needs to set dual WAN, right ?
BrechtSchamp
I'm not sure what you mean. You can load balance between two connected WAN connections. The details about how you can finetune that are in the link I posted before. If you don't have two WAN connections, you can't load balance.
KRobert
