Docusign error: This site can’t be reached The connection was reset.
Ian_Alina
Was trying to log into Docusign and got this error message:
account.docusign.com took too long to respond.
Try:
  • Checking the connection
  • Checking the proxy and the firewall
  • Running Windows Network Diagnostics
ERR_TIMED_OUT
How do you resolve this?
7 Replies 7
BlakeRichardson
Maybe try turning advanced malware protection off and back on again.
Ian_Alina
Thank you. Issue is the same after disabling ang enabling the Advance Malware protection
CptnCrnch
Would you be able to give us any hints about your environment? Otherwise, this ends up in pure guessing. We even don't know what kind of features you're having in place.
Are you able to resolve the hostname? Can you ping it?
Ian_Alina
Apologies for the incomplete details. I have 2 MX84.
I can ping the hostname. I can browse through docusign.com's homepage but not the login page. If I use another connection outside of the UTM then I can login without any issue.
Bruce
What threat protection/firewall rules do you have configured?
  • Advanced Malware Protection (AMP)?
  • IDS/IPS?
  • Content Filtering?
  • Geo IP Blocking?
Any of these could be impacting it. What happens if for the device you are using you change the Policy to the ‘Allow List’ does that then provide access?
Ian_Alina
Good day!
Attached are the current config for the content filtering and AMPAMP.PNGconten3.PNGcontent1.PNGcontent2.PNG
CptnCrnch
Taking a look at Brightcloud's reputation lookup, account.docusign.com is classified as "Business and Economy". So there shouldn't be any issue with your configuration.
Have you tried to "whitelist" your specific client and try again if it works then?
