Disaster Recovery site
RahulPrasadh
I have 4 different sites in Meraki and wanted to set up a VPN to a disaster recovery plan between the sites, where we’d connect by VPN to a backup data center in the event that their primary site was to become unavailable. Do we have any documentation for step by step process.
@RahulPrasadh do you have MXs or vMXs at each site including the backup data centre?  If so and both data centres are set up as hubs, then you can simply set the backup DC as the secondary hub.
If you want to use the same IP addresses etc. in both datacentres then there are more steps and alternate approaches.
RWelch
Site-to-Site VPN Settings
RWelch
Auto VPN Hub Deployment Recommendations
RWelch
Site-to-site VPN
