Disable ports
PasTro
Disable ports
Question from my PCI guy.
Is it possible to close ports 53, 179, 8090, 8181, 123 and 161 from the LAN on a MX67?
The PCI guy did a LAN side Nmap test and those ports was open.
Thanks,
Pascal
Kamome
Also, 123 is for NTP, and 161 is for SNMP.
If you don't use SNMP, you can disable it. But need to open NTP in order to MX can keep correct time.
Some ports are used for  things  like local status  page, splash  page, content filter block message etc.  You can disable those features. Some ports will still be open. But i guess you can not abuse  them unless you prove otherwise 😉
You  have clients directly connected  to your mx?
Port 53 is used for DNS resolution, so you may not want to close that one.
179 is used for BGP.  It's closed on our MX (so you can't connect to it) but it responds to a SYN scan.
8090 and 8081 are open on our MX as well.  I have no idea what they are used for.
Interestingly enough your scan doesn't show port 80, so I'm guessing you have the local status page disabled.
Kamome
PasTro
Thank you guys for your answers.
