Device blocking by MAC
Has anyone found a way to block MAC addresses before the MAC is seen on the network? I have a request from layer 8 to block a group of new machines from being able to connect to the wire or wireless networks. Their only access will be via external wifi and VPN.
I know how to block devices once they are seen by the network but not before..
Thanks for you input.
-Dennis
Accepted Solutions
Re: Device blocking by MAC
Hey @Dennis_S,
You can add clients before they are seen on the network, and apply a blocked policy at that time. Under Network wide > Clients just hit the "Add client" button:
3 REPLIES 3
Hey @Dennis_S,
What @jdsilva said 😂
What @kYutobi said 😎
Nolan Herring | nolanwifi.com
TwitterLinkedIn
