Delete VLAN MX
nst1
Delete VLAN MX
I'm trying to delete a segment configured in the MX
Security and SD-WAN> Configure> Addressing and VLAN
But when selecting it, it shows me the following message
There were errors when saving this configuration: The IP address range 10.10.170.0/24 does not apply to any local subnet or configured VPN.
Where else should I save it?
This segment is no longer used in any configuration
9 Replies 9
NolanHerring
Check your firewall or DHCP settings to see if it might still exist somewhere
Nolan Herring | nolanwifi.com
TwitterLinkedIn
nikiwaibel
"when selecting it"? as in, as soon as you checkmark it?
you have to checkmark the subnet, then press the 'Delete' button. another popup will ask, if you're sure.
nst1
ready, look carefully and I found it even had it in Site toSite VPN
MarcP
DHCP or Firewall, mostly it is still in there and you need to delete it in there first 😉
Tony_Ang
Hi @nst1
Check below and remove the subnet that you want to delete before deleting the VLAN
1) Security & SD-WAN > Firewall
2) Security & SD-WAN > Site-to-site VPN > Turn off first
3) Security & SD-WAN > SD-WAN & traffic shaping > make sure the internet flow or anything that is configured relate to the subnet/vlan that you want to delete, if it's there, remove it too
MarcP
@nst1any solution?
Reggie007
Thank you, have had multiple cases opened with Meraki and could not get this fixed, your post did the trick.
cdavies1525
I had the same issue and noticed that I had references to the subnet I wanted deleted still inside the configuration for Site to Site VPN tunnel ACLs and Syslog server. Once removed the subnet deleted without a problem.
AndreSantos3094
Hello Guys!
I had the same problem and the solution was removing all references of the network in the Firewall ACLs. After I did it, I could delete the network from Addressing and Vlans section.
Hope it helps you all.
