Data centre SD-WAN VPN concentrator design with MPLS and Internet
Jonesaus
quick question on how to design and deploy this, when you have a VPN concentrator in a DC, and each branch and the data centres have an MPLS and an Internet link each, do you still configure the VPN concentrator with 1 uplink interface, then it will form 2 tunnels to each branch over this 1 interface, or do you configure 2 interfaces (ie one for internet tunnel and one for MPLS tunnel)
seems to me only 1 is required, but just want some confirmation.
Both options are valid.
Cisco Meraki's recommend design uses the single interface at the DC.
I personally do my deployments using 2 interfaces so I have greater control over SD-WAN functionality at the DC end.
You are most likely interested in this design:
https://documentation.meraki.com/MX/Site-to-site_VPN/Configuring_Site-to-site_VPN_over_MPLS
9 Replies 9
whistleblower
@PhilipDAth
what do you mean exactly with greater control? Is there any specific configuration/routing needed with 2 Interfaces on the VPN-Concentrator MX?
When you use dual interfaces you can use SD-WAN performance classes.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
So you can do things like tell VoIP to use the best performing path, or you one path for sensitive or critical traffic and another for bulk traffic (perhaps large file transfers or file sharing).
It also means if the primary path fails the system can recover without any human intervention.
whistleblower
OK, I understand that! And how do I imagine the configuration for this on the "one-armed" VPN concentrator and/or the upstream device (e.g. Layer3 switch)?
When you are using one-armed mode you can only use a single interface.  So if you use dual interfaces you can not use one-armed mode.
whistleblower
so you`re talking about the design called "Routed mode Concentrator"... or in other words a HQ/DC where no routed-Core exits?! because the Link you referenced in one of your previous answers is showing the VPN-Concentrator as one-armed...
DN
Agreed with @PhilipDAth  , I would go for the same option in this case .
Happiman
If you have many subnets to advertise from your data center, one arm concentrator  mode is useful. After all, you will run OSFP and form neighbors between MX and your edge firewall.
Note that OSPF in one armed mode can not listen or learn OSPF routes.  It can only advertise AutoVPN routes.
