Data centre SD-WAN VPN concentrator design with MPLS and Internet
quick question on how to design and deploy this, when you have a VPN concentrator in a DC, and each branch and the data centres have an MPLS and an Internet link each, do you still configure the VPN concentrator with 1 uplink interface, then it will form 2 tunnels to each branch over this 1 interface, or do you configure 2 interfaces (ie one for internet tunnel and one for MPLS tunnel)
seems to me only 1 is required, but just want some confirmation.
Accepted Solutions
Re: Data centre SD-WAN VPN concentrator design with MPLS and Internet
Both options are valid.
Cisco Meraki's recommend design uses the single interface at the DC.
I personally do my deployments using 2 interfaces so I have greater control over SD-WAN functionality at the DC end.
You are most likely interested in this design:
https://documentation.meraki.com/MX/Site-to-site_VPN/Configuring_Site-to-site_VPN_over_MPLS
4 REPLIES 4
Agreed with @PhilipDAth  , I would go for the same option in this case .
If you have many subnets to advertise from your data center, one arm concentrator  mode is useful. After all, you will run OSFP and form neighbors between MX and your edge firewall.
Note that OSPF in one armed mode can not listen or learn OSPF routes.  It can only advertise AutoVPN routes.
