DHCP subnets a vlan is missing
Zafrati
Security & SD-WAN -> Appliance status -> DHCP
who can tell me why I only see 2 vlans while they are 3?
TKS
GreenMan
Meraki Alumni (Retired)
If you are relaying DHCP requests to another DHCP server, the MX is then effectively not handling DHCP for that VLAN, so I would not expect to see details for that subnet on the MX.   If you require such details, I would look on the DHCP server you are actually relaying to.
KarstenI
Sometimes it's the easiest reason ... Is DHCP enabled on this third VLAN?
Zafrati
The difference is that set as 'Relay DHCP to another server' rather than 'Run a DHCP server'
GreenMan
KarstenI
Then it is not the MX that is running the DHCP server and there is nothing to show on the appliance page. Relay is used if the DHCP server is a different box, for example your Windows server. If you want the MX to provide DHCP, use the option "Run a DHCP server".
