We are adding Dell thin clients running the new Windows 10 IOT os. I ned to add some DHCP options and would like to run it from the MX84 we have but cannot find a way to add the options correctly. My question is, can this be done or do I need to relay to a windows box? OPtions I need to add are below. If I select custom under DHCP options, I do not have the ability to add a URL for option 165, a false flag for the 167 option, name for option 199.
165 WMS server -
167 CA Validation
199 Group Token
