Creating a VPN For Alcatel VOIP Handsets
Gux
I’m looking to set up a VPN back to the Meraki Firewall, where our Alcatel PBX (Phone System) is connected to. This is for Alcatel VoIP handsets and would appreciate any guidance or documentation you can share. The handsets are very basic and will be connected from home networks, so no static IP. Is there a way to create a VPN like this with the Meraki MX-67?
Thanks in advance for your help.
Mloraditch
Meraki Client VPN is L2TP. I don't believe aggressive mode is supported, as to force encapsulation, I do not know. I'm guessing not as it's not used for regular clients.
13 Replies 13
Blue_Bird
Mloraditch
Here is how to setup client VPN: https://documentation.meraki.com/MX/Client_VPN/Client_VPN_Overview
Do alcatel phones support doing a VPN directly from the phone? If not or if they don't support the options that Meraki supports, you will need a device to do it, I would suggest a Z3 : https://meraki.cisco.com/product-collateral/z-series-datasheet/?file
Gux
You are able to do a VPN directly from the handsets. We did have them working on a different solution, where you enter the Public IP of the office, username/simple password and then PSK. This was then able to establish a connection back.
Mloraditch
In theory Meraki client vpn will allow that to work. As long as Alcatel supports the same cryptography settings Meraki does.
Gux
In theory it should, but I'm not sure you can create a "username" without the need of an email? Are we able to do this?
Mloraditch
No, but couldn't you create a single email account and have all the phones use the same one? You could also create a distribution group and just add aliases to it if you want separate logins. There is no requirement that it actually be separate email accounts.
Gux
The issue is, I cannot enter email addresses on the Alcatel Handsets. For Reference this is what is currently entered on the handsets, I cannot see a way to do this with meraki, without purchasing any other equipment.
 External IP address: (PUBLIC IP)
 PSK details: PSK Password
 VPN Authentication username & password details
 Username: 209
 Password: Password for User
Mloraditch
If alcatel doesn't support typing the AT symbol for usernames or other punctuation then you could setup RADIUS authentication for the VPN. You can use other styles of usernames with that.
Gux
Hello Mloraditch,
Thank you for your support on this. I have been able to obtain a handset which allows me to enter the "@" symbol.
However, I am still unable to establish a connection. This does work on my PC, from the same network. Can you advise if Meraki uses IKEV1/2 and if aggressive mode or force encapsulation needs to be enabled.
Mloraditch
Gux
Ah okay, I was under the impression that Meraki uses IPSEC VPN and was trying to provision the Alcatel Handsets which use IPSEC and IKEV1/2
In this case, you would have to configure a tunnel between the ISP's modem and the MX, and since it is a home network, I don't believe that all ISPs will allow you to configure this.
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-Site_VPN_Settings#Non-Meraki_VPN_Peers
Another option would be to create an inbound NAT on the MX for your Alcatel's IP, but I personally think this is insecure, since you would have to open it to any source since you are using dynamic IPs.
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
The best way I see is if you could make an MX available for each location and then work with Meraki's Auto VPN.
https://documentation.meraki.com/MX/Site-to-site_VPN/Meraki_Auto_VPN_-_Configuration_and_Troubleshoo...
The easiest option is to deploy Merai Z4 teleworkers.  They plug into the back of the user's home Internet router and will automatically build a VPN tunnel back to the MX.
Additionally, they also feature a PoE port, which can be used to power a phone.
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/Z4_Datasheet
Because I like reliable systems I don't have to touch - I would definately be doing this.
