Hello Experts,
I would like to convert a Z3 port 4 to be an internet port for my secondary Link.
Is this feature available on Z3 or it is only available on Z3C ?
Solved! Go to Solution.
Even if it's working, I am not sure if will do so in the future. The documentation clearly states that it is not supported:
With a little luck, it's only the documentation that is wrong.
HI @JamesMutie , I think you can only convert Port 2 to WAN
@UCcert @CptnCrnch When I login on the local page. The port section does show up for me to change role. Any extra thing I need to do?. below is the local page.
This is a very sad story ...
https://documentation.meraki.com/MX/Cellular/3G%2F%2F4G_Cellular_Failover_with_USB_Modems
