Content Filtering permissions
Jonathan_Galvez
Hi Team,
I couldn't find anywhere...but for sure someone know if that is possible 🙂
My question is:
Is it possible to give a user just content filtering permissions? The idea is that they should only be able to change the content filtering configuration but just this nothinelse. Read permissions is not a problem but change only Content Filtering page.
I know in CUCM is possible to make page permissions, maybe on meraki too?
Many thanks and regards,
Jonathan Galvez
The answer is no, to change any setting the user must be an administrator, and you cannot give permission to a specific page in the dashboard.
2 REPLIES 2
You might be able to do this using a third-party solution, Boundless Digital.  They have a system that allows you to create role-based access controls.
https://www.boundlessdigital.com/network-management/meraki-automation/role-based-access-control/
