A client wants to leverage previously purchased equipment (Fortigate). A branch is to come online and the current plan is to use the existing FortiGate as the WAN edge device which will link to HO and possibly the other branches. Are there any preliminary considerations I should look into for such a deployment?
Solved! Go to Solution.
Are you looking to use the Fortigate as the edge of one spoke, the edge of a DC, or as a hub?
So, unless you are following 2, or can accept the limitations of 1, it isn't the best idea
I'm pretty sure that you cannot advertise non Meraki VPN networks to Meraki VPN peers using the same MX. You need two and to use static routes. If you simply mean LANs on the MX, as long as their DG is the MX then they should find the non Meraki VPN subnets.
