Client VPN Troubles
dlowery
Client VPN Troubles
Hey guys, I have a user who uses the client VPN, which has AD authentication enabled. He is a "light" user of the client VPN (only 2-3 times per month) His connection will work fine for a month or two, then it will suddenly break. We've found that the only thing we need to do is reset his password in AD, and he will immediately be able to connect again. His AD password is set to never expire, so I'm not sure why this keeps happening. Any ideas on troubleshooting this issue? Thanks!
Nash
Okay, for Win10, I'm a broken record: Use a script.
There's a lot of problems with the Win10 client that you can fix with PowerShell.
If you do the following, your users will normally have better behavior:
1. Never save their credential
2. Always connect from rasphone.exe. Easiest is to make them a shortcut.
3. Set Encryption to optional. 'Required' is not supported with PAP, as Meraki uses, and Win10 assumes it needs to change the password protocol to satisfy the 'required' setting.
Since we moved to script installs, it's dramatically reduced the number of VPN repeat tickets my helpdesk gets. They also can fix it quite quickly. 3-5 minutes from the time the client gets on the line.
5 Replies 5
Nash
What OS is he on?
For Win10, how are you setting him up? I've got scripts in my sig that make for a better experience.
In Windows, you need your users to not save their credentials.
dlowery
Yes, he is running windows 10. He is using the built-in windows 10 VPN client, but I think he does have a password saved. I will try changing that. I’ll take a look at those scripts too, that seems useful
Nash
dlowery
Thanks a bunch, I'm gonna try out that script today.
Also, that's some awesome, helpful comments in the script, thanks boo ✌️
Nash
Thank you! That's one of the nicest compliments I've gotten about my code.
