- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Considerations when introducing Fortinet Fortigate into a MX dominated WAN.
A client wants to leverage previously purchased equipment (Fortigate). A branch is to come online and the current plan is to use the existing FortiGate as the WAN edge device which will link to HO and possibly the other branches. Are there any preliminary considerations I should look into for such a deployment?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you looking to use the Fortigate as the edge of one spoke, the edge of a DC, or as a hub?
- spoke - create a site to site VPN to the MX in the main site, should be okay as long as you don't need access to/from the other sites etc. due to routing issues.
- edge of a DC - if there is an MX as a concentrator there and it is just an internet edge then this should be fine.
- hub - just don't even think about it, you lose all the benefits of autoVPN/SD-WAN
So, unless you are following 2, or can accept the limitations of 1, it isn't the best idea
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm pretty sure that you cannot advertise non Meraki VPN networks to Meraki VPN peers using the same MX. You need two and to use static routes. If you simply mean LANs on the MX, as long as their DG is the MX then they should find the non Meraki VPN subnets.
