Connecting Viptella SDwan to a Meraki core switch stack?
Vbardy
We just attempted to connect a meraki core switch stack to our viptella sdwan virtual checkpoint firewall environment and every time we attempted the connection to the Viptella TLOC interfaces the ipsec tunnels would not come up.  Does anyone here on the forums have experience with this kind of hybrid set up?  Not sure if we need to add a layer 3 interface to the core??  If you have successfully implemented this type of architecture and can provide some insite, please let me know.
Thank you.
2 Replies 2
Take a look at this.
https://developer.cisco.com/codeexchange/github/repo/suchandanreddy/viptela-meraki-integration
gregpalmer2
Hi @Vbardy,
Are you advertising a default route on the Meraki core? That could be your problem. Check the below document for guidance.
Configure and Troubleshoot SD-WAN Network with TLOC Extension
Updated:February 27, 2024
Document ID:221734
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/221734-configure-and-troubleshoot-sd-wan-n....
