Connecting 2 MXs via the LAN
Bob_Flynn
I have 2 MXs
           MX64 uplink 1 to Comcast Business via static IP
           Subnet 192.168.0.0/24
           Connected on the LAN to Dell PowerConnect 2848 Layer 2 Switch
MX250 Uplink to Xfinity via DHCP IP
           Subnet: 10.0.0.0/24
           Connected on LAN to Dell PowerConnect 2824 Layer 2 Switch
Is there away to connect the 2 subnets via the LAN side so that I can RDP from one subnet to the other?
Everything I have tried fails to work.
This is the basics of routing.
You don't need to use source based route.
For example, let's assume you have the 192.168.10.0/24 network on MX1 and the 192.168.20.0/24 network on MX2.
The first thing is to create a link vlan on both MXs, for example the 10.10.10.0/30 network (VLAN 99) where MX1 will have IP 10.10.10.1 and MX2 will have IP 10.10.10.2.
If MX1 wants to reach MX2's network, just create a route pointing to the link IP of MX2 as the next hop.
So it would look like this, to reach the network 192.168.20.0/24 the next hop is IP 10.10.10.2
Very simple, for the MX2 just do it in reverse, to get to the 192.168.10.0/24 network the next hop is 10.10.10.1
7 Replies 7
eastoscar
you need to implement a transfer network (can be a /30 subnet) and configure a static route on each MX.
regards
Bob_Flynn
Not sure how to do it.  I tried creating a VLAN on each device and then using source based default routes.  But could not access anything on opposite device.  The event log would list ip conflicts.
Couldn't use the static route because it would give an error that static routes cannot include VLANS.
You can create a link network (transit network) between the two MXes and then create static routes to the target networks on each MX
Bob_Flynn
Not sure how to accomplish this.  I tried VLANs and source based static routes.  Connecting LAN ports between MXs.  Couldn't use static routes because it would list an error that static routes can include VLANs.
Downstream switches are layer 2 Dell PowerConnect.
Additionally, you need to create a link VLAN on the switch and configure two switch ports for access mode in this VLAN (one for each MX).
And then select a port from each MX and configure it in access mode on that same VLAN and connect to the switch.
Now you have a link network.
Bob_Flynn
Thanks for helping the old septuagenarian shade-tree IT guy.  It works:-)
