Connect two Internet ISP to Meraki MX75
Roey1984
Hey
We just purchased the Meraki MX75; It will be connected to 2 ISP`s (for redundancy)
What is the best practice in achieving the best redundancy?
Our office contains approx 60 users at most  (Will use VOIP \ AWS etc,) - no internal Servers, all is SaaS.
My plan was the following:
Primary ISP --> 500/500 Mbps line - will be connected to the MX via SFP (fiber)  -Port 1
Secondary ISP --> 200/5 MBPS line - will be connected to the MX via RJ45 cable  -Port 2
Does it make sense? Will it be active \ passive?
Or is it preferred to connect both ISP to the MX via RJ45   (Port 2 & 3)
Any advice would be helpful
Thank you!
AjitKumar
Hi @Roey1984
Congratulations on the New Firewall 😊.
I understand your connectivity plan is good and should work fine.
You can use both ISP's together. You may use the links in Active/Active or Active/Passive. You will find traffic load balancing options available in the dashboard.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
6 Replies 6
AjitKumar
Hi @Roey1984
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Roey1984
Thank you AjitKumar!
Is there any preference to use a single Fiber optic cable & a single RJ45  cable? over TWO RJ45 cables?
KarstenI
As @AjitKumar already mentioned, this setup is fine. Regarding the choice of Fiber or Copper, I would use what the ISP delivers natively. If the ISP gibes you a finer connection, use it. For Copper you would need an additional media converter. If the ISP equipment lets you choose Fiber or copper, I would probably choose copper as that can not be damaged that easily (this is only my experience, others will have a different opinion on this).
One more thing to consider is the Backup link. If the primary ISP fails, the 5 MBit uplink speed of ISP2 will just not work for 60 users in a SaaS environment.
Roey1984
I understand, KarstenI
What is your suggestion in terms of the Backup link?
I just did a double-check, and we currently have a Primary ISP --> 200/200 Mbps line
as for the Secondary ISP that I will take, what are your suggestions if I want it to be Active Active?
a 100/50 line would be sufficient?
Thank you!
KarstenI
That is very hard to tell. One Customers of your size with a Cloud-only approach has a 50/50 Backup link. When the primary 200/200 fails, this link is completely saturated and the users are limited in their work-performance. But at least they still can work.
Roey1984
Understood
Thank you for everything!
