Configure DHCP in MX75
Roey1984
Hello people
I would appreciate your assistance in the following matter.
We bought for our company the next hardware:
Meraki MX75
Meraki MS120-48 Ports
Meraki MR44 (Two Units)
We currently have 100 users, but i want to plan ahead, in case the company will grow.
I wsih to configure the DHCP in my MX to provide 300 ip addresses, and was wondering if the next configuration makes sense:
IP Address:
192.168.0.1
Network Address:
192.168.0.0
Usable Host IP Range:
192.168.0.1 - 192.168.1.254
Broadcast Address:
192.168.1.255
Total Number of Hosts:
512
Number of Usable Hosts:
510
Subnet Mask:
255.255.254.0
IP Reservation Range: 192.168.0.1 - 192.168.0.40
DHCP Client Range: 192.168.0.41 - 192.168.1.254
Meraki MX (Router) - 192.168.0.1
Meraki MS (Switch) - 192.168.0.2
Meraki MR44 (First) - 192.168.0.5
Meraki MR44 (Second) - 192.168.0.6
Does this configuration look OK?
Any recommendation would be helpful
Thank you
6 REPLIES 6
CptnCrnch
Seems perfectly OK to me!
Amazing!
thank you very much
DarrenOC
Personally….I’d have a separate scope for the management IPs of my network devices and other scopes/subnets for data, voice, wireless, servers etc
@Roey1984 I'd avoid the 192. private IP range for commercial use as nearly everyone's home has that and if you want to use client VPN with split tunnelling then it really won't work well.
Better off to us 172.31.10.0 - 172.31.11.255 or similar as that's a lot less likely to clash.
Roey1984
I didnt think about it, good idea!!
I understand
But if I reserve a range of ip`s, isn`t in the same?
