As @GreenMan stated, Meraki templates certainly make it easier to manage multiple different like networks. I do suggest however on reading up on the limitations, so you don't get caught out.
Otherwise invest some time looking into the API. Meraki is designed API first, meaning that most things you can do in the GUI, you can automate using the API.
