Client not using WAN2
juay0004
Hi all,
I am trying to get a device to work solely on WAN2 on my MX67W.
Here are the steps i have done:
->reserved internal IP
->set this reserved IP flow preference on WAN2
->map a static Public IP(within my IP range) to the above reserved IP on a 1:1 NAT with all ports allocated.
->reboot the appliance under the appliance status/tools.
However, when I go on ip4.me it still shows my WAN 1 IP.
Am i missing something?
2 REPLIES 2
Inderdeep
@juay0004 : Check this out
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Appliance_Status/MX_Uplink_Settings
Regards/Inder
www.thenetworkdna.com
Hi Inderdeep,
The config for WAN 1 and WAN 2 on my end is well and established.
Static IPs and both are Active as per your link.
In fact I have done test for failovers and had no issue to have traffic via WAN2 when WAN 1 is disconnected.
I am facing issue in getting a particular device to use WAN2 by default after the steps I have listed.
Not sure if I have missed something that you wish to point out or you have misunderstood my issue but hope this makes it clearer.
Thank you
