Client VPN using WAN2
GaryShainberg
Anyone found a way to allow all the inbound client VPN traffic to terminate on the WAN2 port of an MX.
I am sure you used to be able to do this but can not find the option.
And I being thick or has this been removed?
TIA
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
Jerome_EVAGroup
Hi @GaryShainberg
I think you will need to set WAN2 as primary link to do so.
2 Replies 2
Jerome_EVAGroup
Hi @GaryShainberg
