Are you using 192.168.10.0/24 as the local "home" subnet - if so then it won't work.
Has the phone system ever needed to communicate outside of its local subnet before? If not then I bet it has a mis-configured subnet mask or default gateway.
The next most likely solution is the phone system is configure to not allow connections from 192.168.10.0/24.
