The docs for port forwarding states:
"When mapping a range of public ports to a range of local ports, the ranges must be the same length. (ie, 8000-8500 public must be mapped to 8000-8500 local)"
However the UI allows me to configured:
Usually, the UI is very good at not allowing you to configured things that are not allowed. Is this normal? I have different lengths in the port ranges which the docs says must be the same.
Thanks,
-Jerome
