Client VPN - identity governance
Shukri
Is there a way we can control only company's imaged computers can connect over Meraki's Client VPN and prevent other personal's devices/gadgets from connecting?
I'd like to say no, because it would be very difficult.
You would need to use a third-party MFA solution like Duo and a hardware token that plugs into the computer like a U2F token.  You could potentially use some kind of WebAuthn to do biometric authentication.
https://duo.com/product/multi-factor-authentication-mfa/authentication-methods/u2f-and-biometrics
1 Reply 1
