Client VPN can not connecting.
SardarAlam
I have configure client VPN but can not connect it, my scenario is internet is connected to device after ISP then MX68 then AP. is there any issue with topology? and my public ip is not pinging too. which is showing in dashboard.
Please suggest any solution.
Thank you
Best regards
sa710193@gmail.com
6 Replies 6
SardarAlam
Yes NAT is enabled.
Are you trying to use a client VPN to the MX, or as a client behind the MX?
SardarAlam
i am trying to configure Client VPN remotely.
OVERKILL
Is the MX getting an external IP or is it getting an internal IP from the ISP's equipment?
SardarAlam
MX is getting ip from ISP equipment.
