I'm working through an issue with MX64 as a client VPN server behind a 3rd party (Fortigate) firewall.  I have UDP/4500 and UDP/500 forwarded from the WAN interface of the other firewall to the MX64.  I've looked at packet captures and can see the following:
1) SA completes (client to server ephemeral port 57234 to 500)
2) KE completes (ephemeral port 57234 to 500)
3) ID - client sends ID on ephemeral ports 35121 to 4500, but MX replies with source port 4500 to destination 4500 - i.e. it doesn't reply with dst port 35121 - that the session is established on - so it gets dropped.
I ran a test with another MX NATted behind another firewall, and this worked fine.  The difference was at step 3) - this MX replied from 4500 back to the ephemeral DST port (42854 in this case), then established the connection and proceeded to ESP.
My question is, in the first non-working scenario, why is the MX64 replying from 4500->4500 instead of  4500->35121? I can't fund any reason why it's not behaving in the same way as the working example.
