Cisco Secure Client (AnyConnect) with SAML – Doesn’t Remember Server URL or Okta Credentials
Roey1984
Hi all,
We're rolling out Cisco Secure Client (AnyConnect) with SAML (Okta) authentication for our users.
One of our users installed the Linux client (cisco-secure-client-linux64-5.1.8.122) on Ubuntu and successfully connected using the AnyConnect server URL.
The Okta SSO flow (email, password, 2FA) worked well on the first connection. However, on reconnect:
  • The server URL is not remembered — it has to be re-entered manually.
  • The Okta login window does not retain any credentials or session — users must re-authenticate from scratch every time.
I tested this on my Windows laptop as well and observed the same behavior — the client forgets the server URL after each session.
Questions:
  1. Is there a way to have the AnyConnect client remember the VPN server URL on both Linux and Windows?
  2. Can the Okta SAML session be cached (even partially) to avoid full re-authentication every time?
Would appreciate any insights or best practices from others who’ve encountered this.
Thanks!
KarstenI
What should be modified from default depends on your requirements. The most relevant part is the "Server List," where you add your MX URL and a useful name.
And yes, this is for all desktop operating systems.
10 Replies 10
Mloraditch
I can't speak to Okta, but you can create a profile to save client settings like the URL:
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance/Client_deployment#AnyC...
KarstenI
Did you upload a profile to the MX? If so, the client should present the Name of the connection to the user after the first connect when the profile is downloaded to the client.
Roey1984
Thank you!
I installed the Client Profile Editor, and configured the server URL; I`ll upload it to the server as XML.
It will apply to all OS`s, right? (Windows \ Linux \ MacOS)
I guess we cant do a thing in terms of saving the Okta Credentials?
Anything special you think I should edit here? or leave it as default?
This is the AnyConnect conf in our MX:
thank you so much
KarstenI
Roey1984
Cool
thank you buddy!
You can use my simple profile editor, and on that page it says where you have to save the profile on a Linux machine.
https://ifm.net.nz/cookbooks/online-anyconnect-profile-editor.html
Open a support ticket and ask them to set "forceauthn" to false.
Roey1984
Hey Philip,
Thanks for the link to the profile editor — super helpful!
Quick question though: I was under the impression that if I upload the profile to the Dashboard, it would automatically push it to the correct user directory. Is that not the case?
Also, regarding the re-authentication bit — yeah, it's a pain. But if we set "forceauthn" to false, wouldn't that skip the IDP (Okta in our case) login entirely? How would the user get authenticated then?
Correct, it will push.  Tip - upload it with no extension.  The dashboard always add a .xml extension, even if the extension is already .xml.
Forceauthn means it uses SSO.  It will use whatever policy you have defined in Okta.  If you say a login is required once per week - that is what will happen.
Roey1984
Perfect!
Thank you for this Philip!, appreciate your help with this
