Cisco Anyconnect is not connecting to active directory on my MX75
rsterchele
Hello, About a week ago my Cisco Anyconnect stopped authenticating users on the AD.  Nothing changed on the MX75 that I'm aware of.  Was there a change to the MX?  Did I miss a firmware upgrade or something?
6 Replies 6
michalc
Hi There,
It’s unlikely the MX would switch things up out of nowhere—those devices tend to stick to their routines! Did you happen to schedule a firmware upgrade sometime in the past week? Or maybe there were some other tweaks made to the network recently? Oh, and one quick check—can the firewall still chat with the AD?
I’d suggest kicking things off with an authentication attempt and running a PCAP toward the AD to see what’s up. Are we spotting that LDAP exchange? Does everything look happy and healthy? Let us know how it goes—we’re here to help!
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
rsterchele
Okay.  Thank you.  When I try to refresh the LDAP Groups I get a TLS error.  I'm not using certificates in my setup.
I get this error.
ldap_Start_tls    Server is unavailable.
Thank you
Mloraditch
I would double check your domain controllers and their GPOs to see if someone may have enabled LDAP signing. It's also possible it may have been active and the certificate it uses has rotated or expired.
Mloraditch
You can go to Organization Firmware Upgrades to see the most recent changes and when they  happened.
You may want to reboot your MX. While there are a variety of possibilities for what's going on, there could have been a Microsoft side change/patch. I've not heard of a recent update causing LDAP or NPS issues, but that doesn't mean it hasn't happened.
Have you attempted to do a packet capture or view the event logs on your relevant server to see if the requests from the MX are getting there and what might be happening?
My guess - the certificate expired on your AD controller.  Are there any certificates on your AD controller that have expired around that time?
Pro-tip.  If you have Office 365/Azure AD/Entra ID - authenticate against that.
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance/AnyConnect_Azure_AD_SA...
rsterchele
Thanks to all. I added a self signed cert and every thing  started working
