Change to How Group Policy is Applied to a Client?
Twitch
Morning everyone. I am trying to apply a newly-created group policy to some clients, but I no longer see the option to do so under Network-Wide > Monitor > Clients. It used to be where the yellow highlight is in the screenshot below. I no longer see the option for any clients in our networks.
Has the method to apply the policy changed? If so, I can't find any documentation for it.
Thanks!
Navigate to  Network-wide >  Monitor > Clients, then check the boxes of the clients that you want to allow list or block. Click on the Policy drop down above the client list, and select blocked or allow listed. To apply the allow list or block on a per-SSID basis or only on the MX security appliance, select Group policy.
There is all you want to know.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying...
JamesT91
It's on the bit to the left of where your screenshot shows, here:
Twitch
Thanks! The option is there if I tick the box next to the client in the client list, but it is no longer there if I click on the client and open the client details page.
Regardless, I'm all set.
Thanks again!
Client Details page:
Client List:
