Certificate based authentication for Meraki VPN
ShenSimps
Hi does anyone know if user or device certificates can be used for authentication with Meraki VPN?  With the Windows client or a third party VPN client?  It looks like Meraki Wifi APs support EAP-TLS and can use ssl certificates for authentication but I can't find anything about VPN.
I appreciate any help you can offer!
Thanks,
Inderdeep
As @Inderdeep mentions, the Cisco AnyConnect client has certificate-based support.  Note that Cisco AnyConnect is an additional licence fee, but it is not expensive.
You'll also want to generate a VPN profile configured to use TLS authentication.  You can use my online tool to do this.
https://www.ifm.net.nz/cookbooks/online-anyconnect-profile-editor.html
One caveat though. You cannot implement cert-based auth alone. You have to use cert + user creds on Meraki.
