Can the MX64W be linked/integrated with Umbrella?
Has anyone done this?  I am not clear as to how after upgrading the firmware on the firewall to an Umbrella compatible version.  Not finding Umbrella options anywhere.
Accepted Solutions
Re: Can the MX64W be linked/integrated with Umbrella?
If you've followed the linked instructions, you're running beta firmware, and you're still not seeing it - have you contacted support?
8 REPLIES 8
Thanks for this. I guess my problem is when I follow the directions I do not find a place to enter new credentials because the new credentials option simply doesn't exist for me on my dashboard. Unless it only shows up after I create the API in Umbrella?
You are org admin and can see the organization part in black menu pane saying organization and you can enable API, right?
Have you upgraded to the beta firmware for your MX?  You do need to be on the 15.x firmware for this option to be available.
I did both.  Do I now generate an API key (in the Meraki dashboard) for the credentials option to show up?
@Nash that is what I just did. I contacted support to enable the feature which I assume is what needs to happen...
They had to enable the feature.  They as in support.
